Radioscanner.Ru Radiosignals
Начало раздела
English version
Versión en Español
Все про SA
Скачать демо
Сигналы
Форум
Поиск
E-mail
The updating of SA from 6.0.5.0 version to 6.0.5.21 version.
Small updating VMW module.
Updating affects VMW module. The Standard enough situation is represented on the pictures below.
The ACF value is received, and there is a necessity to see the signal itself with this development after the phase detector.
In the old versions it was necessary to instal/specify this value in VMW module by slider, at that the slider is not intended for this purpose, because it allows to set approximate values of an interval of decomposition very roughly.
In version 6.0.5.21 the last measurement in WF module is remembered as default value for VMW module.
In addition, the possibility of operative changing of decomposition interval in line, by direct correction in the field of indication(as it shown on the image), is added.
The left-mouse-click on the digit is increasing the value by one, the right-mouse-click is decreasing the value by one.
New possibility supplements the old methods of regulations in VMW module, providing more flexible and convenient functionality as a whole.
Good Luck.
Файл создан: 08 Jun 2009 22:54, посл. исправление: 08 Jun 2009 23:00
© www.radioscanner.ru, 2009-2012; ©miniBB Site Engine | загрузка: 0.019сек.
