*** 2012 ***
SA update to version 6.2.6.7 from 07 March 2012, description.
SA update to version 6.2.6.5 from 24 Jan 2012, description.
*** 2011 ***
SA update to version 6.2.6.4 from 10 Nov 2011, description.
SA update to version 6.2.6.3 from 30 Sep 2011, description.
SA update to version 6.2.6.0 from 22 Aug 2011, description.
SA update to version 6.2.5.8 from 30 July 2011, description.
SA update to version 6.2.5.4 from 19 July 2011, description.
SA update to version 6.2.5.2/3 from 25 June 2011, description.
SA update to version 6.2.5.0/1 from 14 June 2011, description.
SA update to version 6.2.4.8 from 24 May 2011, description.
SA update to version 6.2.4.6 from 15 April 2011, description.
SA update to version 6.2.4.4 from 22 March 2011, description.
SA update to version 6.2.4.2 from 28 February 2011, description.
SA update to version 6.2.3.8 from 20 February 2011, description.
SA update to version 6.2.3.6 from 11 February 2011, description.
SA update to version 6.2.3.4 from 10 January 2011, description.
*** 2009 - 2010 ***
SA update to version 6.2.3.3 from 28 December 2010, description.
SA update to version 6.2.3.0 from 4 December 2010, description.
SA update to version 6.2.2.8 from 17 November 2010, description.
SA update to version 6.2.2.5 from 28 October 2010, description.
SA update to version 6.2.2.4 from 23 October 2010, description.
SA update to version 6.2.2.0/1 from 18 October 2010, description.
SA update to version 6.2.1.8 from 10 October 2010, description.
SA update to version 6.2.1.6 from 05 October 2010, description.
SA update to version 6.2.1.4 from 20 September 2010, description.
SA update to version 6.2.1.2 from 15 September 2010, description.
SA update to version 6.2.0.9 from 31 Aug 2010, description.
SA update to version 6.2.0.7 from 22 July 2010, description.
SA update to version 6.2.0.6 from 09 July 2010, description.
SA update to version 6.2.0.3 from 25 June 2010, description.
SA update to version 6.1.2.7 from 31 May 2010, description.
SA update to version 6.1.2.4/5 from 9 May 2010, description.
SA update to version 6.1.2.1 from 4 April 2010, description.
SA update to version 6.1.2.0 from 25 March 2010, description.
SA update to version 6.1.1.7 from 10 March 2010, description.
SA update, v 6.1.1.5 SA update, v 6.1.1.6 from 1-3 March 2010, description.
SA update to version 6.1.1.3 from 20 February 2010, description.
SA update to version 6.1.0.8 from 20-th January 2010, description.
SA update to version 6.1.0.7a from 15-th January 2010, description.
SA update to version 6.1.0.5 from 05-th December 2009, description.
SA update to version 6.1.0.3 from 29-th October 2009, description.
SA update to version 6.1.0.0/1 from 18-th October 2009, description.
SA update to version 6.0.7.2 from 3-th October 2009, description.
SA update to version 6.0.7.0/1 from 30-th September 2009, description.
SA update to version 6.0.6.7/8 from 16-th September 2009, description.
SA update to version 6.0.6.4 from 5-th September 2009, description.
SA update to version 6.0.6.3 from 22-th August 2009, description.
SA update to version 6.0.6.1 from 19-th August 2009, description.
SA update to version 6.0.5.8 from 16-th August 2009, description.
SA update to version 6.0.5.6 from 5-th August 2009, description.
SA update to version 6.0.5.4 from 25-th Jule 2009, description.
SA update to version 6.0.5.3 from 14-th Jule 2009, description.
SA update to version 6.0.5.21 from 8-th June 2009, description.
SA update to version 6.0.5.0 from 26-th May 2009, description.
SA update to version 6.0.4.9 from 16-th May 2009, description.
SA update to version 6.0.4.8 from 12-th May 2009, description.
SA update to version 6.0.4.6 from 12-th April 2009, description.
SA update to version 6.0.4.4 from 31-th March 2009, description.
SA v 6.0.4.0 basic version, from 5-th March, 2009.
SA free - the demo version with resrricted opportunities.
Updating of the versions is realized by simple reinstallation. If you install the update into the same directory, where earlier version is situated, then the active/current key is remain valid for the new version also. The old version is removing/reinstalling by the new version. If you change the directory of the update installation, then you will need to activate the program again by the old key.
Файл создан: 17 Apr 2009 18:03, посл. исправление: 07 Mar 2012 23:05 |
